MMAFIGHTER121
Is there any way to quicken the shifts? I know a lot of people use tunes to increase the pressure, does this quicken them up or just make them "firmer" to give it a sportier feel?
Line pressure increases the firmness, with out a tune you can try this: From Quik LS: "The transmission software "learns" the characteristics of your transmission and adjusts the pressure to try to optimize the shifts. It does not learn driving style, only the time it takes to make a shift. You may be able to make the shift a little closer to optimum with this technique.
First, warm the vehicle. The transmission needs to be above 130F before it will start learning. This will take about 5 miles of city type driving in the warmer months. Once it is warm, do the shift that isn't as you like it. Repeat the shift 5 times and it should be as good as it will get. You need to make each repetition at the same speed. A shift that has learned at 40 MPH will not do anything for a shift at 35 MPH.
Every shift except automatic downshifts will learn. Engagements, such as park to reverse, reverse to drive, etc, can especially benefit from the above technique."
