P1518 is IMRC stuck open. Chances are they are not stuck open and you have a bad IMRC.
My 97 has P1519 (stuck closed), I did some diag and found they were carbon closed because of the little old lady I bought the car from never got the RPM's up over 3000.
I took my intake off, removed the IMRC's and brake cleaned the :q:q:q:qt out of them in a solvent tank at work. Easy job to do but messy. I did first try the Seafoam through the PCV hose and in the tank but it didn't work. You can check the operation of them by looking at the back of the intake and stabbing the throttle and watch to see if the cables move. You can even stick your hand back there and move them by hand.
