craigh
Jokken, did you ever find a fix to the idle speed problem? I have the same car with 93,000 on it. Won't idle down quickly when releasing the throttle and the idle speed jumps around a lot. Any info would be helpful.
what code?
The same code for the aic which I replaced
There is no "code for the AIC." (I think that you actually mean "IAC", but there is no code that says that is bad either.)
