just got done replacing the radiator in my 2000 LS. I was surprised no issue with my reassembly... I also got to replace most of the fluid in the hydraulic fan setup :Beer
the radiator was a bit of a job, it took me way too long, I was very happy the car started and just went, without any temperature issues, after I had it all apart for so long, and I was hung over this morning when I finished the job, in the rain...
but the elation was dampened a bit when I came to the light by my job. The same old issue happens: when coming to a stop (clutch in, in gear or not) the rpms drop well below 1000, the car almost stalls and then bounces the rpms back up to 1500, and then back down almost stalling again, repeat (with the AC on it does stall sometimes). This happens 80% of the time, i can sometimes, not always, get it to idle right if I jab the gas, and when the RPMs come back down they settle correctly around 1000.
This is coupled with another annoyance: about 50% of the time when coming to a stop if I don't press in the clutch the rpms stay where they were 2000 or even 3500. I have to pay attention more how I even end up in this state, usually I press the clutch in while coming to a stop so.... when in this state, stuck at 3500rpm, once I press in the clutch, the rpms drop to normal, or more often than not they drop and do the bouncy thing I explained above.
some aspects of these kinda makes me wonder if there is a transmission component that communicates (speed/gear/wheel-speed) with the computer and maybe that is what is wrong? keep in mind this is a manual
any suggestions?
i've changed the IAC valve twice and redid the PCV valve and hose... or do I have a vacuum leak somewhere, or air being pulled in post MAF?
thanks
any suggestions?
thanks
