Idle air control replacement
cips8404
st petersburg
My 2002 ls 3.9 had cel on so brought it to be checked out, turns out to be iac code so I just replaced it with motorcraft iac and gasket. So i unpluged the negitive battery cable for about an hour and drove it and light came back on, so i decided to have a garage clear the code with scanner and it came on again. I dont know why the light keeps coming on anybody have any ideas
Yes, it keeps coming back on because you have not fixed the problem. Those obdII codes never say to replace part X. They are just the start of diagnosing a problem. Why don't you post the exact five character code that you are getting, and maybe we can help point you to what you need to test.
B1896 - Door ajar lamp battery short
p0113 -ntake Air Temperature Sensor 1 Circuit High Bank 1 (This is the one causing the light to come on)
p1000 - just means that you recently disconnected the battery or cleared codes.
I noticed that the intake air temp sensor was unplugged while I was changing air filter. Hahaha I guess I overlooked that
