Whats the easiest way to change the IAC on a gen 1? I can get the bolt on the drivers side. What do you have to remove to get to the pass. bolt? Thanks.
remove the wiper cowl, that helps make room...i ground out a slot on the valve itself and partially screwed the bolt in then just slid it over and tightened it down
