Frogman
- Joined
- Jul 11, 2005
- Messages
- 6,914
- Reaction score
- 1
I finally sat down and came up with a list of the parts I've either already bought, or are in the process of buying, for my Mark VIII project:
Oops, the secret is out, but since the car's almost done, IDNGAF anymore.
Cooling:
Two 15,000 LB GVWR Stack Plate Transmission coolers
Griffin Radiator - Can't find anyone else who can custom build me one. suggestions are welcome.
Engine:
Teksid Block
298 c.i.8.5:1 CR Forged Rotating Assembly
Ported, Polished, Ferrea SS Valved, 7000+ RPM Springed Heads
Cams reground for forced induction. Don't have specs. Not that I would really know what to do with them anyways.
New timing chains, tensioners and sprockets.
New accessories, like WP, AC compressor, Alternator, PS pump and pulleys.
96-98 Cobra Intake
SCT Mega Meter
Twin Turbonetics 60 Series Hair Dryers with a .61AR - this may change -
Kook's Headers - Long bung FORD O2 sensors
Cobra High Volume Oil Pump
ARP in all the right places
Fuel:
Aeromotive Fuel Rails / Lines around the motor. The rest will be a setup suggested to me by a member here. Thanks, you know who you are.
BEGi RRAFPR (Rising Rate, Adjustable Fuel Pressure Regulator)
72lb/hr Matched High Impedance RC Engineering Injectors
Three Walbro 255 lph/HP Intank Pumps - with a nifty relay set-up that will kill one pump if three are overkill
Tranny and rest of the drivetrain:
Racer's Edge 3200 Stall Converter - this will have to be restalled once the package is done -
Bauman Engineering tranny with lock-up
Denny's MMX Driveshaft
Carrier Brace
Ford Racing 3.73 Trak Loc Gears
Raxles Halfshafts
Polyurethane Bushings
Suspension:
98 Cobra Bilstein Shocks
Addco Swaybars
5x4.5 Mustang hub conversion on all 4 corners
Stopping:
13" Crossdrilled/vented PBR Dual Caliper Brakes on the front
Stock size cross drilled/vented brakes on rear.
Wheels:
ASA AR1 18" wheels. Black with machined lip.
Eagle F1's wrapped on the wheels
Supporting hardware:
NGS Tester
X-Cal 2
Panasonic Toughbook for datalogging.
I know, how are the turbos mounted. Well gentlemen, that's still a secret for now. Tight fit, nevertheless.
What, no IC? nope. I may go with a methanol injection setup though. Haven't decided yet.
Now you see why I don't have a mod list in my signature....
Cooling:
Engine:
Teksid Block
96-98 Cobra Intake
SCT Mega Meter
Fuel:
Carrier Brace
Raxles Halfshafts
Suspension:
Addco Swaybars
Stopping:
Wheels:
NGS Tester
X-Cal 2
