i need sizes,please help!!!!!!!
viiiball
holden
ok, found blue reducers, for c-a ow i need sizes to get, the rubber at the end of throttle tube is gone, so what is dia of throttle tube out let, then what is the mm equivelant of 3 inches diam. then what is size of maf(end that faces the throttle tube) here are the sizes what should i order here are the choices.
-----70mm-64mm
-----70-70
----- 77-64
----- 77-77
thanks for your help, i alo got a line on filter with heat shield...i'll keep you posted. thanks for help :Beer :feedback :feedback :feedback
Well, 3" = 76.2 mm.
I THINK the stock MAF connection at the intake tube is 3-1/2" diameter. BUT the stock MAF is inside the airbox and it is the airbox that actually connects to the rubber connector.
I do know that 80mm MAF units require a rubber ring to upsize the diameter to fit the intake tube connector.
