will a 2005 3.9 work in a 2000 as long as i use my original heads wiring harness and intake mani etc? really all i need is the block and internals so i'm thinking it will work. i can get a 05 3.9 with 23k for 700 bucks so i need to know quick
it's a tough question - I have not seen the two blocks side by side - but it would concern me that all the little things (like accessory mounting, even the oil filter) are different and likely it's those little things that would mess you up.
You wouldn't thing that the internals (crank, rods, pistons, rings) would be too different, but then again - the piston tops maybe....
Sorry - I wish we had more info on that level of detail. if we ever hurt the lower-end - it certainly would be nice to know we could buy a newer block...
