chagan
I'm having a few electric issues that I hope someone helps me with. I'm gonna list everything that is going on because I'm looking for a common link of some sort.
Always had the alarm go off when the car got wet, so I disconnected the speaker so I could sleep at night-nothing major yet
Had a new Kenwood head unit installed (professionally)no problems after the install
My tranny went- started revving in the 30 to 40 mile range without moving then banged into gear.
Pop replaced the tranny with an identical unit (got the car from him & he had a spare; he was a head mechanic at Mac Trucks for ages-knows his SH** but...
Went to pick up the car and the remote wouldn't open the door
opened the door with the code and the alarm signaled, then had to put the key in the ignition before I could hit the disarm button to start the car (door locks opened and unopened several times before I was ready to start it) yes, the battery on the remote was replaced first to check the simple things.
The car seems to slide between gears, not hard shift between them. I don't know much about the Lincoln, but when the tranny was broke, I knew it. Now I think it is not much better.
On the way home that night the headlights started to flicker on and off randomly-no pattern at all-but only on low beam. Switching to high beam and there was no flicker. The panel of the headlight switch was extremely hot
Now when the car got wet the door locks opened and unopened repeatedly over several minutes all by themselves as well as the alarm going off. (without the speaker of course)
I noticed a great loss of response in performance- I used to only have to depress the gas pedal an inch or so all the way from home to work- now I had to give it much more pedal and it started to miss when I did this. The car also didn't kick into passing gear without much persuasion- just kept slowly revving with the low tone of the non-passing gear.
Brought it to a place to fix the headlights so I could drive at night- they said the alarm was shot so they took out the under hood fuse and the fuse box module to totally disable the alarm. They replaced the headlight switch because the relay was shot. This fixed the headlight issue.
There was a time when the computer stopped responding (kept telling me that I was almost out of gas when I just filled up and resetting the DTE did nothing. (seems ok now that the alarm was disabled).
My temp gauge stopped working somewhere along the line and when I got the car back the car seemed to have some balls back and the temp gauge worked briefly again. I watched the temp gauge return to non-working status as it slammed from the normal zone to hard left. (appears to be getting current, just opposite from what it needs.) At the same time the performance dropped off again. Maybe a major coincidence but I don't know.
Now this may be a multitude of different issues, but I thought I'd list them all together to see what can be grouped together.
I would truly appreciate some input from you guys to see what I should be looking into. I find it too much of a coincidence to have all of these things happen relatively at the same time without some common link. Please help
