I disassembled my fan motor at the shroud (easier than wrestling with the high pressurer line) unfortunately I lost the keyway that fastens the star-shaped rotor to the shaft...Lincoln only sells the entire fan/shroud/hydrallic motor as a unit...anyone have a fan motor or damaged fan or shroud that includes the motor FOR SALE???? (its the aluminum motor at the center of the fan with 4 bolts and the high pressure line at the top and the return line to the right side)...Need help
Thanks Don
Thanks Don
