Hub Conversion and front end noise question
Lunchbox
Horseheads
Ok I am not only new to the Lincoln Mark Viii but i am also new to the forum. I would like to know what cars you can get he hubs off from for the conversion? Lastly I have a noise that I believe to be coming from my height sensors. The upper control arms and ball joints have been replaced and everything else is tight like new. I have a 95 and every time I go over a bump in the road it sounds like the front end is going to fall out. But I can duplicate the sound by jiggling the sensors. So that is what I believe is the cause. So the question is what would be a solution to fixing the noise. There is nothing wrong with the sensors or the bags so coil overs is out of the question. Thanks for all your help. Eric
Hub question could be found in search, but fronts from any mustang 94-04, rears from an IRS cobra.
I'm not sure about the height sensors, but you may be able to bend the little tabs that keep them attached so that they hold tighter. I don't know, i'm just guessing since I can't see it with my own eyes.
I'm having a hard time believing that you could hear any noise that the sensor could make while driving the car.
If it "sounds like the front end is going to fall out", then it's got to be something more substantial, like the sway bar end links or ball joints.
