I finally was able to change the Power Transfer Unit (PTU) Fluid within the Lincoln mkS. The area was very tight but I was able to get it done. Here is the step-by-step on how to drain and fill the PTU lubricant for the 2009 Lincoln mkS AWD:
			Thanks!Don't forget to also do the RDU and transmission.
Fluid changes are the easiest way to make your car last.
Have you considered adding a drain plug to the PTU?
Fairly simple to do and really makes service much easier.
