How to Bypass Hydraulic Pump w/ V6?!?
Lincoln LS
  1. Farmer_Gann
    Farmer_Gann New LVC Member
    5
    Aug 31, 2019
    Walnut Grove
    Hi
    I've got my electric fan ready to swap in, but for the life of me can't figure out how to delete the old hydraulic pump/pulley. Unlike you fancy v8 folks, this v6 doesn't play nice with a shorter belt (from the looks of it).
    2000 LS V6
    The only person I found in search that solved the issue hasn't been here in 5 years and didn't post pictures or part number :/
    Thanks all
  2. 04_Sport_LS
    04_Sport_LS Dedicated LVC Member
    3,145
    347
    Jun 12, 2012
    Somewhere around Lake Erie
    Since Ford used basically the same engine in the Taurus and Escape... why don't you take a look at those and see how things are routed. Might just require a bracket and/or pulley swap.
  3. FDR
    FDR Dedicated LVC Member
    1,967
    130
    Jan 20, 2014
    Central NJ
    Or a gen 2 V6 which is routed exactly the same other than the pump...
    IIRC they have a bracket and extra idler pulley at the top passenger corner to put the belt in the right shape
  4. Farmer_Gann
    5
    Aug 31, 2019
    Walnut Grove
    I'm going hunting for that bracket and idler in the morning - awesome tip, thank you!
  5. Farmer_Gann
    5
    Aug 31, 2019
    Walnut Grove
    Got it running thanks to you getting me on the right track - Thanks Again!
    $15 Hydraulic Pump Delete (V6)
  6. FDR
    1,967
    130
    Jan 20, 2014
    Central NJ
    That was 04_sport_LS that suggested the Escape/Taurus, but hey, nice find!
Share This Page
