zolemite Active LVC Member Joined Apr 16, 2007 Messages 94 Reaction score 0 Location Franklin Park Mar 17, 2008 #1 to change the coil packs or what ever they call are ignition wires. I have a number 5 cylinder misfiring on a 98
ground_zero298 Dedicated LVC Member Joined May 5, 2007 Messages 1,897 Reaction score 0 Location Michigan Mar 17, 2008 #2 Easy as it gets, take the 2 bolts out of the coil covers and start pullin coils. I take the strut bar off to do the back ones.
zolemite Active LVC Member Joined Apr 16, 2007 Messages 94 Reaction score 0 Location Franklin Park Mar 17, 2008 #3 what parts do I need to buy??
ground_zero298 Dedicated LVC Member Joined May 5, 2007 Messages 1,897 Reaction score 0 Location Michigan Mar 17, 2008 #4 You might just have a fouled plug. So at the most you will need 1 coil pack and maybe a plug. When mine was missing, it was just a bad plug
zolemite Active LVC Member Joined Apr 16, 2007 Messages 94 Reaction score 0 Location Franklin Park Mar 17, 2008 #5 any idea which one is the number 5 cylinder??
zolemite Active LVC Member Joined Apr 16, 2007 Messages 94 Reaction score 0 Location Franklin Park Mar 17, 2008 #6 found it. I replaced the coil and it fixed my problem. Thanks ground zero
ground_zero298 Dedicated LVC Member Joined May 5, 2007 Messages 1,897 Reaction score 0 Location Michigan Mar 17, 2008 #7 dam that was quick
zolemite Active LVC Member Joined Apr 16, 2007 Messages 94 Reaction score 0 Location Franklin Park Mar 19, 2008 #8 I thought I was going to have to take it into a mechanic. It was running really bad and now all is well. All for $45 can't beat that.
