How do I flush the cooling system?
If you drove my car all you have to do is drive it and it flushes itself by overflowing cooland all over the place.
pop the trunk, on the left side there is a hidden compartment. Press the lever down and it flushes the coolant out. Lift the lever back up and refill, pretty simple.
since you took the red pill you can turn your heat on high with car running and open bleeder valve all the way out until the system is dry and steamed up...then you go the a junkyard and find a new motor and replace
Near the coolant overflow tank, coming straight out from the firewall. It's pictured in the tech article you're reading. It's a black rubber hose with a black plastic fitting at the end. You'll see the screw driver slot on the end of it, allowing you to open the valve.
Mark
