Scallywag
was lurking thru forums and found this thread which matches my situation
http://www.lincolnvscadillac.com/showthread.php?t=41666
only my situation went a bit further as to my buddy was behind the car checking for the light when i pressed the brake, but instead he saw 0 light and smoke began coming out of the trunk. so of course i disconnected the plug and put in new fuse so i can put the car into gear etc
smoke!? yikes!!! i hope it's just the wires that got scorched and nothing else, though it did smell plasticky...
So anyways, now I want to test the neon beam, because if the beam itself is bad too, then i might as well get the entire housing unit as opposed to just the ballast Glitch offers, but since I'm not savvy with cars as i am with PCs, i need some advice.
hopefully the neon beam is ok
Thanks
My 98 Mark Viii rear center light doesnt work. i checked into it and it actually was unplugged! so i thought, easy fix and plugged it in, then i noticed it wouldnt go into gear, because of the brake press. fuse being blown. i put a slightly bigger fuse in just to see if the light would come on to test it. but the light didnt come on and would blow up to a 20 amp fuse. ( it is supposed to be a 15a) .. Anyone else had this issue? What could it be ? a short inside the ballast? thanks
Thanks
