Warden
So last night I hear running water coming from the basement - oh chit.
The sump pump has been pumping water into a clogged line and spewing all over. Luckily I was home and heard this quickly. I was able to shut off the pump and attach a new clamp to keep the water in the pipe. I then plugged in the pump to see if the pressure would push out any blockage. No luck.
I do not think it's ice as it's been warm and the 4 feet of snow in my yard is slowly melting so it freezing lately doesn't seem likely, possible but not likely.
I think an animal got into the drain line (4" round corrugated pipe).
Here's how the pipe system is configured (it's not the smartest design)
THe pump pumps from the sump pump hole up a 2" PVC to about 12" above grade outside. The pipe then turns 90 to go out the concrete wall and is exposed outside above ground. It then 90's again and goes into the concrete slap for the back stairs. It then 90's again in the concrete. Then I am not sure exactly how but it then turns another 90 degrees and increases to a 4" corrugated pipe and collects the down spouts from the gutter system. I know for a fact that the installer used all 't' fittings not 'y' fittings so getting a snake down one of the downspout lines is out of the question. I think I am going to have to dig up where I think it transitions to the 4" corugated and cut the line. This is under my deck and I could install a 'y' and run the pipe up to above grade and install a cap and use as a future clean out.
I could then get a long heavy duty snake into the large pipe and use a smaller snake inside of the 2" pvc with the really close and tight bends.
This will be a temporary fix, I thnk I will spend some time and money to dig up the connections and put in 'y' piping and possible heat trace the portion above ground.
Oh, and maybe I should install a grate over the exit of the pipe to stop anything form going up there in the fisrt place. IF ONLY I HAD DONE THIS OVER THE SUMMER LIKE I HAD PLANNED AND FORGOT. Such a dumb ass. And now I get to payfor it.
