Hmm exhaust problem now?
warrioralumni08
Oklahoma
Well, my exhaust is fabbed up. With open manifolds, it would start right up and run. With the new exhaust, it took a couple times to start up, and had to give it gas to let it get idle. Stock manifolds, no cats, removed third muffler and cat, has a long Y going into the single stock pipe, exiting into duals. Maybe not enough back pressure? Or probably my idle air messing up? I would rev it up and it would die down quick and stall. Any help is appreciated.
Ill check it out and see then, maybe a vacuum line is no good since they have been sitting for a bit. Maybe I broke one, who knows. I want to lean towards the iac, but don't want to spend anymore money.
Easy way to check for vacuum leaks: with the car idling, use a propane torch (not lit, of course) and spray propane around the top of the engine. If the engine races up, you've found your vacuum leak.
Ah, very good idea! =] Thanks alot!
are your o2 sensors in and working?
Yes, they are in, I will have to check if they aren't working. Should be fine though.
Also, I drove her around for the first time today, runs nice and smooth, but it takes a couple seconds for the rpm to drop down when you let off the gas, like it's sticking. Bad tps maybe?
