Daviddc114
Okay, so my passengers HID stopped working all of a sudden, not while driving it just wouldnt go on one night. So i ordered a replacement bulb and no luck. I tried the replacement on the left side connection and it worked fine. I had to leave and couldnt do any further testing but is there another common problem? Are the rh and lh headlights on different fuses? Id die if it was just a fuse, especially because the plastic cover behind the bulb broke so i had to spend another 30 on a replacement one! If its not the fuse am i able to switch the rh and lh connections at the ballast to see if its the ballast? Any help would be appreciated. Also as far as future proofing, are there any fixes for the plastic covers breaking? Thanks
