HID fog lights...
car_lost
Miami, FL
Okay... so my cousin has an '02 LS V8 with stock fog lights. I have searched and found that the bulb is an H10 (correct?). So with that said, do they make H10 HID kits? We upgraded his stock head lights to 6000K HID's and would like to do the same to the fog lights but I havent found any kits.
Any help would be appreciated. Thanks.
-Carlos
Also, I have tried searching, but the term HID and Fog are both too small to use and i've tried using them both at the same time as "HID fogs" and "HID fog" but i get nothing. So yea... i'm a noob to THIS forum but i'm pretty good on getting around them. :D
Try www.xenondepot.com
I saw H11, but didn't find any H10 with a quick glance.
So the whole time this car has been out... NO ONE has put an HID kit in their 2002 LS fogs?!?!
I think a member by the name Propane put HIDs in his fogs. Somebody correct me if I'm wrong, but I'm pretty sure that out fogs lights can fit a 9005 bulb. The same one used in our high-beams. And it should be very easy to find a 9005 HID plug and play kit.
He did. He bought three HID conversion kits from me and installed them in the low, high and fog lights. He used the 9005 bulb for the fogs.
PIAA'S SUCk
I had the xtreme super white piaas in my 9006,9005 and in my fogs 9005 2 weeks ago my low beam blew out and a couple of months after I got them my one of my fogs blew out and @ 75-80 bucks a pair THAT SUCKS. so Im going to try the HOENS low beam and the silver star 9145 fog. Ive only had them less than 2 years.
so 400X3? and that's a lot of HID's
his car proably looks like a light house.
Here's 2 pics of propains LS.......
On the 2002 to get a 9005 bulb to fit you have to "shave down some of the housing on the bulb...If your going to do this get some cheap bulbs to play with first.....If you look at the 9005 vs h10 there is very little difference but I have 9005 metal whites in mine and I had to shave the one flat bade that locks into the fog light....I saw somewhere who had them for the ls....I will find it and re-post them....I was thinking about it but I dont wanna spend 300.00 bucks on fog lights...I can already see plenty with the HID headlights....But hey its you car...I would do it if I had the cash laying around maybe....
im gonna go with the same brand we bought for his low beams, but thanks though :D
also, hid's in the lows and fogs is 100% worth it... its look absolutely awesome!
here is my car with 8000K HID lows and fogs... soon i will have 6000K for the reverse lights ;)
I wish Angel Eyes could be installed on +2003 LS'. DAYUM. That will look CRAZY rolling with HID Fog's and 2 sets of 'eyes' from the headlights!
I'm putting HID in my low beam and fogs too.
Good luck.
car_lost did you know that with the 4500-5000k you can see better (whiter) on the road......I have seen 6000k on the road (inside the car) I have 4500k in mine and I see more on the road....If you put some 5000k in the headlight You might like what you can see.....the 8000k-15000k headlights just put out colored light and It looks F-IN crazy and I love them But I looked into it and you can see better with the 4300-5000k IMO....
oh i know, the higher in Kelvin rating you go, the lower the light output. my car (2003 acura tl-s) came stock with 4300k HID in the low beams. i then upgraded them to 6000k and then i switched it out for 8000k and added 8000k fogs. believe me, i have NO trouble seeing :D i also dont blind anyone since i have them aimed correctly.
gt95coupe said:
With lows highs and fogs on the HID system will that be too much for the factory switch and wiring?
im not 100% sure, but it should not do any harm.
