Flynbrd
Ok so I found a wrecked 03 ls with hid lights. What do I need besides the headlight to make the swap. I assume the ballast but I have no idea where it's at. Thanks
The factory HIDs are all self contained in the headlight assembly. You'll need to file a key way off of the connector on your car to get it to plug into the new headlights. That should be all there is to it. (Note that LSes with HIDs from the factory have an external headlight relay, that the LSes with halogens don't have. However, others that have added the factory HIDs have said that it worked fine without having to rewire and add the relay.)
BTW, are you sure they are HIDs (do they have the yellow warning stickers)? All the plastic housings (halogen or HID) have HID molded into them.
... I know I must add a relay to power each HID ballast...
