Here is the pic of my 80MM MASS AIRFLOW, keep on or take off?
Its easy to pull the intake, if thats the issue. The only thing I don't like is removing the cross over tube. I'm pretty sure that needs to be removed. Its been a while since I did that, before I modifidied the cross over bolt down tabs to easily remove the alt. I would check to see all bolts are tight first. those gaskets are pretty tough.
welcome to 3 days ago, like I said.
Even at a disadvantage we still beat dealerships techs with the progosis.
LVC FTW!
NOW.. the second gens commonly have an intake manifold leak between the upper and lower intake.
ok, so the guy did all sorts of tests and the IMRC is working fine, the problem is a vacuum leak coming from the drivers side intake manifold and it seems that i need a new intake manifold gasket, there is (2) upper ones and (1) lower one, I guess the lower one is the under the the IMRC. Could this very well be my problem
