It's been a while but try this. Remove screw from door panel located near the latch or above (open the door and look above the childproof lock out). Pop off the surround trim from interior handle and remove screw. I don't think there are screws at the bottom of the door but check. Now gentley wiggle the door panel and pull up and slightly out. Interior door handle stays on the door,no need to remove.
