rwurst918
My name is Ryan. I have been on here for a few months when i bought my LS8. I have had countless problems with the car including a bad master cylinder, bad rear brake calipers (couldnt get them to bust loose with a c-clamp, and yes i did open the bleeder valve) bad transmission solenoid, very bad brake pads all the way around, brown brake fluid in the brake lines, and now the timing chain tensioner guides (I Think). My car has the ticking when i start it up for about one second. What I am wondering is what is bad? I read in a discussion that the plastic that holds the guides in can break. I do not know which tensioner they are talking about. I have an intermittent vibration that shakes the steering wheel and shakes the car above seventy miles an hour. I think it may be a ball joint. Does anyone have any similar problems? Where the hell can i find a Chiltons at for this thing? This site has helped me fix everything so far with perfect results. Please help or I am screwed with an $1800 bill for the tensioners.
