2002 LS V8 sport:
Switch on dash won't activate trunk release solenoid, was working a few weeks ago as that's the last time I can remember using the dash switch to open the trunk.
I can still open the trunk using the remote, so I know the solenoid itself is ok and the latch isn't jammed or anything.
Pulled down the cover and check the switch itself with my meter and the switch is working, get good continuity when its pressed in. Then I checked the wiring to the switch and neither of the wires has any power to it.
To compare, the fuel door release is on the same plug and has 12V on the outer of the two wires.
Anybody have a wiring diagram they can look at and help me out here in terms of where to look next? Or experience with the trunk release wiring?
Thanks,
Mike
Thanks,
Mike
