Help with navigation disc
orangeteg04
Rochester
Hello I just purchased a 2004 ls with the THX audio and navigation system but the disc for nav is missing ... Is there a specific disc I would need or would any disc from lincoln work ... Thanks
Any
And even used ones can be pricey so you mise well just dish out the 199 for the most recent edition.
I found a few on eBay for about $50 ... But your correct on navteqs site new is $199... Your prob right tho I should get most recent for the money !!!
Actually best use of your money would be an aftermarket double din. Even with the NAV cd the thx is not very good. Very outdated. If you have a smartphone you can download a GPS app and simply connect the phone to the double din and it will use the phone as a GPS interface. Look for a double din that has this feature.
You can search and find the disc as a download but you need the -P version, not the -D version. I think the update is up to 7P online or 8P via Navtec. I have the original 2005 set of several discs and a newer update single disc that came with the car.
