Title says it. Hope someone has a clue. I searched and found one thread that said "LS does not have a steering wheel lock." Well now mine does.
Rest of story - I was replacing tie rod ends. Had both sides disconnected. Was able to loosen the locknut on passenger side with much difficulty. Screwed new tie rod end on to locknut position. Wanted to get wheel in good position to insert the TRE bolt into the control arm hole. Pushed the wheel a bit and got the bolt in. But now it's in a bad position to install and torque the nut. Could not turn the wheel by hand now with TRE in the hole so went in the car and turned the steering wheel and it went to end of travel and I heard a 'click' and now it's locked. Will not move.
Joegr? Anyone? TIA.
Joegr? Anyone? TIA.
