Sifrino3
How in the hell do I get it back to normal! Damn!!!!!!!!!!!!
Well proud Papa ... how'd LSC NYC's reccommendation work out?Sifrino3 said:How in the hell do I get it back to normal! Damn!!!!!!!!!!!!
Sifrino3 said:Okay. I got it to 12. Which is where I want it. But then I clip that clip in, which you are suppose to take out to do your timing. I plug it in and the timing is way off. Is that fine?
12 without clip
20 with clip. (Or close to it)
NYC LSC said:Yup. That's about right. When you put the SPOUT connector back in, the ECM adds in some timing.
Good job, dude. Glad it's running better.
MAT88GT said:hehe, atleast the oil pump driveshaft didn't get stuck against its boss in the block...that can make for a real pita
Good to hear you go it figured out!
btw the distributor doesn't need to point exactly at #1 at tdc since you have ~30* (depending on distributor orientation) to play with
Do you mean the stupid little tab that holds the base of the distributor in one place?NYC LSC said:The SPOUT connector.
C'mon, you should know this...you did your timing at the track!!![]()
OldSchool1 said:Do you mean the stupid little tab that holds the base of the distributor in one place?
That little sucker has an official NaMe other than, "That stupid little tab"?
I know what I don't know and I know that I didn't know what the hell a spout connecteor was.
Thanks.
