Hey guys-
I wanted to get some op's before I decide what to do with my 06 LS
So I spring a leak in my radiator hose and fix it. I go to start the car and
'clang clatter clunk!!!!" It sounds like I threw a rod, that bad. ugh.
I immediately shut it off and after my heart rate went down I tried it again and the same thing. It runs- but I'm afraid to let it run more than a second or two.
Here's the deal: A couple times when I turned it over, it sounded like it didn't have any compression. You know, it didn't have it's normal rhythm, the cadence was off. However, it starts and the noise is enough to scare anyone. I can't imagine the car starting with a thrown rod or spun bearing, so I got to thinking a few things. Something sounds loose, like it rattling around-clanging so to speak but I'm not going to let it run long enough to damange it any further
Could it be the timing chain tensioner? Could it be the timing chain itself? Could it be a valve?
-it seemed to have a miss. I thought maybe a plug had broken off and got into the cylinder I just changed the coil packs and plugs. Just to be sure, I pulled all 8 plugs and -nothing. They only have like 500 miles on them at most.
But the thing that throws me is the fact that it starts, the rhythm being off on the starter and it runs like crap-the short time I've let it run anyways. I was reading about the plastic tensioner on the gen 1's but this is an 06. All fluids are good, I've always run synthetic and it's got 149 on the clock. ANy help guys- If it needs a new motor, I'm not going to fix it and it's going to break my heart. Thanks
