What a horrible day. With a bulb out, I decided to convert so I bought an HID system with digital ballasts and internal firing. Installation went easy and we used a 9005 kit and used a nice clamp to hold the bulb in place. The wiring was a pain,we used t-taps and tapped into the green power on the pass. side and the blue power on the driver's side as well as the grounds. When we fired it up the pass. side came on but not the driver's side. We turned it off, checked the wiring and it seemed okay but when we tried it again we had NO lights. At this point my mechanic friend re-did the wiring as he hated the t-taps and still nothing. So I drove home on icy roads with the brights on.
I tried turning them on and off like troubleshooting said and didn't use the auto feature as I heard that could be a problem. My mechanic thinks the ballasts are bad. I have heard that some kits need a wiring harness to get the proper voltage directly from the battery. Right now I have a daytime only car. Any ideas??????????????
Thanks, JOHN
Thanks, JOHN
