Help alternator not charging
93hotrodlincoln
watertown
Does anybody have a wire diagram for the charging system? The middle (black) wire on my regulator is missing I need to know where it goes. thanks.
it doesn't go anywhere.
it's 3 wire plug, but only the two outside wires do anything.
Okay, that's what it looked like.
I cant get this new alternator to work. With the 3 wire plug in and the car running im not getting any voltage off the terminal. Any ideas?
bad voltage regulator.
failed diode plate / rectifier bridge.
bad rotor. bad coil.
is it a reman alternator? cuz most of them suck.
It is a reman but I had it tested and it worked fine... The old alternator I had in the car was over charging 17-18 volts in the car but when it was tested at the parts store it only pulled 11 volts.
