Help 1955 Capri brake upgrade problems
Razorback1999
Lodi
Looking to up grade my brakes from the treadle vac system to dual master cylinder mine came with power brakes is there a system I can use from the parts store that will fit?
Master cylinder plugger on treadle vac is 6 inches with firewall plate.
with out fire wall plate from fire wall to brake pedal fully pulled to set position is about 4 inches.
Fire wall mount holes are 4 bolt hole 2 1/2 from top to bottom and 3 inches left to right 4 inches cross ways.
Please help
