Heater core?
Blair
Katy
So about a week ago, started noticing an Antifreeze smell in the cabin, AC is blowing cold, but a visible mist, and today, Low engine coolant light came on. Heater core leaking?
Sounds like a good diagnosis to me. Do you any damp areas on your floor carpet?
Even if your leak was outside the cabin, you would still smell it, BTW...
The dash needs to be pulled. When I first got that Mark I changed the blend door. It's hard to tell when the heater core will go out.
Is the anything on your window? Does it taste sweet? Check to see if you also have a damp floor like stated before. Plan a good weekend for that job. Have you ever pulled a dash?
