Heated seat
04charcoal
Hamilton, Ontario
Hello all,
I'm having an issue with the driver side heated seat. When it's cold and only when it's cold the heat turns on for 2 min then shuts down. Also if you turn on the heat and wait about 2 to 5 min before sitting down it will work just fine. it's like when sitting down you cause it to over heat and it turns off. but, like i said it only does this when cold. any help would be great.
Thanks
Sounds like the butt pad ductwork is getting crushed. It's a known issue, and there is a TSB. It requires duct replacement. The duct is a foam pad with tubes though it. I bought one about 5 years ago for $30. I think I still have the TSB at home, and I'll try to PM it to you tomorrow.
Exactly.
Pictures of the foam duct.
http://www.lincolnvscadillac.com/showpost.php?p=927925&postcount=14
Other info you will need to get the seat apart and back together to replace this.
http://www.lincolnvscadillac.com/showthread.php?t=54278
