Headlight ?
slackjoebill said:
Is there anyway to break apart the black adhesive in my headlight?
One word..........NOPE! You can but you will destroy the headlight.
ok what about this, i have a headlight that has had the seal broken and i have re-sealed it with silicon, can i break that?
It depends on what kind of sealant it is. Just take a razor knife and cut along the seam of the headlight. This should allow you to open the headlight. This will not work on the OEM sealant since it is all the way on the inside of the headlight.
That tells me youve had it apart before because you state that you re-sealed it.... Just do what you did before...
here is a previous thread that goes into more detail.
http://www.lincolnvscadillac.com/showthread.php?t=8982
hope that helps.
