headlight thingie lol
Jeffintampa
Tampa ish
Hey anyone got an extra headlight in the garage that is for parts? If you have had a headlight out a Gen 1 its the little white post (mine broke) it is on a plastic plate with 2 of the connectors that hold the light in place.
Thanks,
Hoping Jamie may have one
The local Pick-N-Pull currently has three Mark VIII's. I could probably pick up the parts you need for the asking.
BUT I'm not realy sure what it is you need. Looking at my headlamps I see a short white post behind the leveling bubble and black, white, and blue posts that are threaded onto metal studs.
Can you get me a little more info?
On the drivers side of the headlamp there are 3 clips that hold the headlight in the 2 on the right side 1 is the white one that is broke, and under that is a lever one. My white on broke, you will need to take the headlight out and if you look how the white one is connected it is on a bracket type thing and I am pretty sure there is like 2 or 3 screws that will take that bracket off.
Thanks alot for the help as there are no lincolns in the yards around here
all 3 of the adjusters have to be twisted with needle nose pliers to remove them, there are no screws holding them to the housing, they twist clockwise about a 1/4 turn and the wings line up with notches in the housing then you simple pull them out.
So you only need the white plug that is by the bubble level, right?
