Headlight Assembly Question
Bullschmidt
LVC Photographer
Ohio
Yes, as far as I remember, they are the same apart from the low-beam reflector, ballast and the plastic ballast cover.
You will still have to cut them open though.
I can have a closer look after work.
Cut them open to replace the low beam reflector correct?
To replace both low and hi-beam reflectors. It's one piece rather than being separate, mounted by 3 posts, each with a ball joint at the end.
What cracked? The lense or back part of the housing?
The lense itself is messed up. I tried to fix it and ended up making it worse. The idea was get a replacement housing and have you swap the lense when you do some angel eyes for me :D
