kevinspann
I am looking to buy a 1995 Mark that is having an "almost" overheating, and coolant loss issue. The owners have had the water pump, thermostat and radiator replaced, apparently to no avail. When i went and looked at it, it was about half full of coolant. They say there are no leaks.
-I checked the oil, there was no milkiness.
-I didnt smell the reservoir to see if there was an exhaust/fuel smell.
-There was no smoke out of the exhaust when it started, or for the short time it was running. I used to live next door to them, and never saw any smoke come out of the car either.
-When i pulled the cap off of the reservoir, it seemed like it was under pressure
-When the car was running, i had the cap off of the crossover tube. There was a faint white mist coming out of it, but i never smelled anything that seemed like exhaust/ Fuel
-There are no leaks inside the car (aka heater core)
What may be the issue is that somewhere along the way someone didnt properly fill the system. And from what i read, the thermostat *could* be installed backwards, but looking at one, it seems like a hard thing to do. Another issue ive read about is the oil filter adapter gasket.
Anyways, what do you all think?
Edit: If i did a compression test on the car, what would i be looking for?
