jk52781
I recently purchased these HID lights as I saw them on the Lincoln forum awhile back. Everything is hooked up but I cannot go from low beam to high beam or high beam to low beam. For example, right now the car low beams work but if I use the lever next to the steering wheel to turn on the high beams all the lights go off. If I manually disconnect the wire from the low beam to the high beam I can get high beams but same thing if I go from high beam to low beam the lights will shut off until I go back to high beam. My car guy and I have done everything possible and connected all the wires according to the diagram in the manual. Could it be related to the negative circuit from the battery? Please help if possible.
http://cgi.ebay.com/ebaymotors/Xeno...ryZ36476QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
