LsUnV2
I have 03+ headlights and as some of you may have raead in previously threads i took them apart and put new lenses in. i notice some moisture in there which made it look crappy and it was actually wax that must have been on rag when i cleaned the lens on the inside. anyway, halos always go bad so i was wondering where i can get the grey glue to put them back together. this will make it easier in the future to replace the rings if need be. i just spent about two hours getting these apart again and i also scratched a lens lightly.
. also i was thinking about using the lens restorer in the inside of lens to make it perfectly clear, has anyone done this ??? i was hesitant to try this in case the restorer degrades and will be noticeable on the inside ......thanks in advance
