thaywood
Okay. I'd like to get some input/opinions. When I bought my new front air spring/shocks for my '96 from Arnott, I put green slime in the springs prior to installation in the hopes of curtailing any dryrot leaks that may occur in the future. That was over a year ago and so far, no problems. Since then I have read a few threads here in which people have said not to do that because bad things can happen. Like the slime can get into the compressor and gum up the system. I don't think that will happen since I just put it directly into the springs themslves, not the air lines. Also, I have heard that the slime crystalizes and cuts the air springs causing leaks. I don't know about this, but I have had a bottle of green slime sitting in my utility room for a couple of years and it is just as fluid as it was when I bought it. No signs of crystalization. The reason I ask is that my '97 LSC may have a possible leak in the front springs. The shocks are still in excellent condition and I don't want to buy new ones yet, nor can I afford it right now. Here's what it's doing: If I park it at night and leave the suspension on, the front end will be on the ground the next morning. If I turn the suspension off when I park it, it will not drop at all. What I think is that there is a dryrot crack in the spring at the fold where it sits in "curb mode". If I turn off the suspension before it vents, it won't drop. If I let it vent, it drops. So I figure a little green slime in the spring will settle at the bottom and keep it from leaking around that fold. Any other suggestions, other than buying new ones? Also, I really like the stiffer ride of the LSC shocks. Arnott doesn't make shocks specifically for the LSC, nor does anyone else that I know of except maybe Ford. And I sure al hell can't afford Ford's price. So, does anyone think I'm nuts, or should I give it a shot? Thanks.
