Got Problems With The Ford Dealer And LS
TarzansLS
Los Angeles
I Took My 2000 LS To The Ford Dealer. Paid $98 For Whats Wrong With My LS. I Got Wats Wrong With It No Problem. Can You Guys Help Me With These Problems
Rightside Catalytic Converter
Oxygen Sensor Right Side
Cat Monitor
Coil
A/C Filter Replacement
But They Didnt Tell What They Did Wrong To It. Those :q ers Broke 2wo My
Rotor Bolts.....
Please Help Me LS Assistants
Yeah for real. The stealership here tried to charge me 3 grand to fix the track on the sunroof. They started telling me they needed to take the seats out and everything, must have thought I was stupid cause I'm young.
For the first 3 on that list I would check Team Ford to the right ->
Coil - Go to ebay and buy the whole pack for 150
A/C filter - get your oil changed and they should pull it out, check it, and replace it for you for a minimal charge, they did for me.
Try this...
I found this site:
http://deneau.info/ls/
Not sure what year your LS is, but it may help. If it is out of warranty, try working on it yourself. 1/4" set of metrics, a small set of gear wrenches in metric, and you'll be set.
I am not a mechanic and came across a Lincoln LS that barely made it down the road. With the exception of a starting issue that I'm working on, it is running strong. I have changed the MAF, IAC, injectors, coils, spark plugs, valve cover, O2 sensors, and the car is running better.
