Got my wipers working
Brozly
Grand Haven
I had to put my turn indicator on high beam and raise it toward right turn to get a swipe from my wipers, I also had HIDs installed that shut off on high beams, so I tore into the column, spliced the wires for the lights, and took the Multi switch apart, I found a broken wire at the connector going to the turn lever, soldered it together and,... I have functional wipers. :p
(I know, I should have took pictures... :( )
Really not a whole lot in there to go bad, I think there were just two sliding contacts, one for the four ways, and the up/down for the brights.(I needed a feeler gauge to slide that back in.) I cleaned off all the contacts and gave them a coat of dielectric grease, probably better than new now... :D
