Brozly
I had to put my turn indicator on high beam and raise it toward right turn to get a swipe from my wipers, I also had HIDs installed that shut off on high beams, so I tore into the column, spliced the wires for the lights, and took the Multi switch apart, I found a broken wire at the connector going to the turn lever, soldered it together and,... I have functional wipers.
(I know, I should have took pictures...
