Gen2 v6 Code P0316
n8bachelor
Bentonville, AR
Someone help!
Tonight on the way to dinner I get an illuminated engine light (sometimes it flashes) and the car is noticably studdering. So I stop by Autozone before they close for Christmas and have the codes read. It reads a P0303 and a P0316 error code.
Does anyone have any experience with the P0316 error code??
The P0303 is a misfire in cylinder 3 caused by Plugs, ignition wires, coils OR Vacuum leak OR Injector fault OR High/Lo fuel pressure (according to the Autozone printout).
The P0316 code is described as a "Crank sensor condition" which is caused by a fautly crank sensor OR sensor wiring OR something called a trigger wheel (again according to the Autozone printout).
I was hoping for a unplugged wire or loose hose under the hood that I could just fix up myself. No such luck. 2nd best would have been the PCV valve which would be covered under an extended warranty from Ford (got that letter last year).
Either way I am 200 miles from my home visiting family for the holiday and wondering if I can make it home with the car missing like it is...
This link seems to indicate the two are related and if I fix the misfire the P0316 error will go away.... of course it says nothing about a "crank shaft position sensor" being related to that error either. I do tend to trust a Ford published document over Autozone...
No sh*t Sherlock. I'm not new here. I know how to search. I did search for what I asked
but with no results. I was able to find much information on the P0303 code but very little on the P0316. That is why I titled the thread the way I did. Any ideas?
If you are refurring to me my name is gcwimmer and I was just saying what I found and how I found it. By the way you responded I'm sure other will jump in and help.
This is a public form.
Mr. Wimmer, The manner in which you presented your information was taken (perhaps incorrectly) as derrogatory.
I will continue my search.... and am open to anyone's advise who has seen a P0316 error code before.
Thanks,
