Gen 2 steering wheel on Gen 1?
k9t8m
Rollin' Twankies
Peoria, L-inoise
Is it possible to retrofit a Gen 2 steering wheel on a Gen 1? Are the air bags interchangeable? Thanks
:) I don't know if this will help, But I took these numbers out of my 1997 service manual...If you have a gen 1 service manual, You can see if the numbers match?
steering wheel # 3600
steering column lower yoke # 3n725
" " shroud # 3530
drivers side air bag module # 043b13
Now I'm assuming these are ford numbers! It worth a shot:D
Airbags YES
Steering Wheel NO (without swapping the entire column due to differences in the steering shaft spline)
Is it maybe a year specific thing? The 96 I have has a different spline than a 95. So a Gen II may work on a 96.
Well I took the steering wheel from my 95 and tried to put it in my 96.
i thought the Gen2 wheel was "keyed" and the Gen1 had the splines......like all other Fords of the time, the Gen2 wheel being just for Gen2............
never taken mine off, just from what ive read.........
maybe jamie can dig some up and solve this with some pics :D .............
and the FR500 wheel fits Gen1/T-Bird/Cougar's......not Gen2 :(
Thats the problem I had. The 96 is keyed and can go only two ways - right side up and upside down. Then when you have to account for the cruise wires, only one way.
I also found this out when I did my custom steering. I forgot it was keyed and just put the steering in without considering I should center the steering wheel when I finished it off. I figured I could pull it and adjust a couple degrees here and there. But nope, no go.
all wheels 93-96 interchange, why the person above had a problem with a 95-96 wheels is odd, but any wheel from 93-96 will swap, they are double keyed with a flat edge on both sides, 97-98 will not fit 93-96 unless you have a very large hammer, a welder, or swap over columns, which obviously none of the above are even worth attempting, 97-98 wheels are splined.
