Is there any way to adjust the headlights for up and down movement on the HID 98 Mark Viii? I get flashed brights occasionally. Or is it perfect but people percieve the HID light as too bright?
yes there are two adjustment for each light the is a brack adjusted on the fender side with a plastic nut on it that adjusts right and left the then between the high and low beam there is a low spot that has another plastic nut that is either white or grey and it controls up and down BE VERY CAREFUL THE NUTS CAN STRIP OUT VERY EASILY
