I had a dimwit high-school girl side-swipe me from the 'A' pillar to the middle of the back door on the passenger side of my '02 Sport. I was lucky enough to find a complete set of '06 doors for $100.00. I spent a weekend getting the 'B' pillar back in position---it was pushed in by 2-3 inches---and getting both passenger doors hung and aligned. And a couple of weekends fiddling about before I was satisfied with the paint match.
ALL the electrics work just fine except for the front window. The mechanism is OK in the wrecked door but I don't care enough to go through all the change procedure on the motor. I have more important things to do on the car although I suppose I'll do it some one of these days. No one rides with me as often as once a month.
Good luck!
KS
...Auto dim sounds cool, Ill have the complete doors with mirrors so if it is just a matter of adding wires I can do it. Or if I need anything else from the 06, like a module or whatever I can still get it from the same car...
... If you want the driver's side mirror to auto dim, you will have to add a gen II rear view mirror and some wiring...
...You said smart window motor? Is that the auto function to go up or down? Mine only has auto on the driver's window to go down. Id love to add the up and down option to both fronts. ...
Good luck!
KS
Yes, auto up and down on both front ones. However, the smart motors are used to talking to the gen II electronics. Maybe with some creative wiring and relays you can get them working locally. Global open and close may be very difficult.
So all you need to do is swap motors? How about the side mirrors, do they work from gen 2?
Global open is when you open the windows with your remote?
