93mkviii
I've been searching on the weight distribution of the Mark VIII and came across this info from tccoa.
"There are two major revisions of the Mark VIII - Gen1 (93-96) and Gen2 (97-98).
LSC coupes were available 95-98 with slightly more HP (10) due to dual exhaust & CR.
Gen1 are OBD-I EEC-IV systems except for 1996 which was OBD-II EEC-V.
Gen1 have a slightly thicker piston crown and more desirable for performance builds.
EEC-IV have coil packs (DIS) while EEC-V systems have COPs.
Body style is slightly different for Gen2 then Gen1 (headlight/taillight change).
Gen1 headlights are horrible. Clear Gen1 available w/HID late 95 and all 96 LSC's.
LSC models have 3.27 gear rear end, all others have 3.07 ratio.
LSC models have slightly more compression (9.9:1 CR) vs non-LSC (9.8:1 CR).
Steering Ratio changed from Gen1 to Gen2 (14.1:1 vs 17.25:1).
Front/Rear Weight Distribution changed from Gen1 to Gen2 (63%/37% vs 55%/45%).
Gen2 Marks are slightly wider 74.8" than Gen1 Marks 74.6"."
Mainly i'm focused on the compression, steering ratio, and weight distribution. Anyone know if this is true?
